  • Replies 149
Posted Images
ok well..
Just dropped the quote around now, was my only chance..
She was home.. her car there, heard noises inside.. but she didnt want to answer the door.. Dont blame her with me standing there..
left the quote and a letter in the box explaining the quote and gave her till the end of the year to get back to me.. as i have called up and pretty much booked the car in for 1st week of Jan.
https://www.sau.com.au/forums/topic/92806-smash/page/6/#findComment-1804704
Thought id just inform you all..
There is a bit of action goin on..
Car is goin in to the workshop Tomorrow arvo, Guy is making a start on it, Very exciting.. :)
But this aint mean ive heard from the chick..
Thats a diff story which will be taken on a diff path.
https://www.sau.com.au/forums/topic/92806-smash/page/6/#findComment-1832360
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
