Yup l'd say its a dolphin kit too .... well at least Fb, skirts & rb. The rear wing looks more DAYZ to me.
http://www.freeway-dolphin.co.jp/ae_top/ni...ea_c34mc-bl.htm
Nice car by the looks of the pics, dual sunroofs, 18" bbs wheels, kits, exhaust ...... almost same as mine .... cept thats an s2.
I just won an auction last night for the wing in this link!! Good bye volvo look! :(
http://www.freeway-dolphin.co.jp/ae_top/ni...ea_c34mc-wh.htm
Edited by [ STAGEN ]
Thanks for that
That makes the the front bar, skirts, rear bar and grille approx $3300 plus fitting
Not including the rear spoiler
With the other extra's on the car, it starts to look like good value, compared to a stock one.
That rear wing helps to hide the square look of the rear
That little bit a do not like about Stagea's
When this car arrives in the next couple of weeks, I will get a much closer look and get a bit more serious about buying it.
It is time to get rid of the VX wagon, and sadly the R33
The white wagon car will match my boat nicely
Just need to fit a pair of gold BBS wheels to the trailer :)
Im loving that wing STAGEN! :) Top work
Thanks bro ..... l wanted something BIG to loose that volvo look .... l think this pretty much fills that requirement!!
Same here .... hence the first thing l had to do as l didnt have a wing, was get one.
A DAYZ one was going to cost me about $900 landed, which for a wing is a bit extreme in my book. This one only cost me $500 landed .... thankfully was a quiet auction!! :)
  • 5 weeks later...
i have no wing... would love one but they sure are few and far between. who should i go through? im just after a dayz wing. i KNEW i shouldve got a dayz - if i hadve known the dramas in getting a body kit for a stag i probably wouldve. havent seen one in my colour but, so its all good.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
