When i accelarate and then de- accelarate black smoke pours out of the exhaust. It has not done this before.I have just installed a k&n air filter and had the timming belt replaced, would this have anything to do with it ?
Also
Does anyone know what the oil pressure should be at idle and when running
Edited by Justin78
https://www.sau.com.au/forums/topic/93086-black-smoke/
Black smoke generally means it's running rich which is good I guess.
It could be running richer now possibly because the timing was adjusted when the timing belt was changed or the AFM was tampered with when the air filter was installed.
A little black smoke while pushing it is normal for most jap cars as their ECUs were tuned to run slightly rich. So I don't think there's anything for you to worry about. :)
Edited by ToF
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1680024
A little black smoke while pushing it is normal for most jap cars as their ECUs were tuned to run slightly rich. So I don't think there's anything for you to worry about. :angry:
Cheers mate
Is there anyway of leaning it up slightly.
I dont have any surging so i guess it cant be to rich ( i dont know), there sure is a fair bit of black smoke when the blow off valve releases
Edited by Justin78
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1680326
Black smoke usually shouldn't be coming out unless your really punting it hard or maybe just when you back off the throttle and it's dumping excess fuel into the system..
is it diong it while you are idling - or mainly pushing hard..
Best way to check A/F ratios is put the thing on a dyno.. also get a conzult cable from someone and check that your O2 sensor is working correctly and that it isn't just defaulting to running rich..
Doesn't sound like there is too much of an issue, might just need to be cleaned up a bit.. also maybe change your fuel?
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1680461
I started it up this morning drove it down the road and it just stalled and would not boost.
I ended up taking it to the workshop put it on the dyno and still the same problem not boosting, no power, and black smoke, after all this it ended up being that the cat converter had sh*t itself and was blocked stoping all airflow
Thanks for your help
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1681850
If its running rich can it screw the cat up fairly quickly or does this happen over time
What spark plugs did you put in and what gap where they set at.
Im also getting alot of backfiring since the cat change does anyone know why it would do this or does this lead to it being rich again.
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1691462
My skylines running hell rich under full boost, cant remember the exact air/fuel ratio but it was hell high, they told me to get a Power FC or something similar so they could lean the mixture a little, under full boost and the richness made 179rwkw with VG30, got told the PFC would get me to 200+ no worries. Cars generally backfire after high revs during a down shift or going off acceleration, shouldnt be too much to worry about
https://www.sau.com.au/forums/topic/93086-black-smoke/#findComment-1691934
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
