Hope your all sitting down.
Weather deflector kits are around $340.00 delivered.
Stock is ex japan.
Cheers,
Ken
Ken will you be able to get these when ever as i do want them and I will just have to wait a while to get them as the house building budget is starting to blow out big time now.
cheers ICE
My drivers side one is cracked pretty badly, had one of my mates lean up against it, and dint realise it was plastic, yeah yeah dont even get me started on it, but yeah I wouldnt mind a new set as mine are a but faded and the plastic looks like it is deteriorated to the point where they need replacing, but at that price I'd rather just do without them :P
Oh and I heard a rumour that without them the windows leak in the rain.................?
I've got them, but they're both cracked, and i almost lost the drivers side on the Hume.
a quick squirt of silicon gel fixed them up, looks a bit funky but they're not broken and banging anymore.
for $340 i'll pass, mine do alright for now
Can get for you whenever. Do you have mob number?
CBUS is why your house is sooooo expensive.
Had to drop the CBUS as i had to buy a bigger patch of dirt as the house wouldn't fit on the first one. Its the purpose built home theatre that took a bit $$$ and now just found out I have to spend $15,000 on a retaining wall, not happy. I will PM mob number.
Cheers ICE
Mine are in perfect shape, no cracks, not loose or anything. I may reseal them on with some sikaflex though just to be safe as you guys all seem to loose/nearly loose them on the freeway's
x2 ... mine are in mint condition.
Better look into sticking them on with something else as well, as l drive on the freeway quiet a bit.
Stock is ex japan.
Cheers,
Ken
Hi Ken, does the price drop if we buy multiple kits? Packing multiples all together should be a lot easier.
:) cheers :)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
