I've found some pics of this Stagea while browsing through Google Images (below).
Now l'm pretty hooked on this look, actually l prefer this a stack more than just the clear s2 tail light look, but l need some help.
Does anyone know who makes them, well the lights/covers & bigger no. plate area. I've searched through the yahoo jp auctions and come up with nothing, same with searching on the net.
Otherwise if l can't find anything l might just paint mine and see how they look.
anyway .... here's the pic .... and any help would be great!! :D
https://www.sau.com.au/forums/topic/93617-tail-light-help/
I dare say its a hole new hatch with half parts for the lights. Otherwise, it is a bog, fibreglass, fill, smooth, spray custom once off thing.
But yes, i really like it as well...
My car, for reference
Here is what i would like more...
For just the eyelids, could use some thin aluminium, bend and cut it to shape and then get it powdercoated white or the colour of the car, if they can match. Else, get it sprayed.
Edited by AlexCim
https://www.sau.com.au/forums/topic/93617-tail-light-help/#findComment-1690473
BTW, G, you can get eyelids for 2500 yen from yahoo auctions, if you need them. :P I can throw them in the next car that comes over.
http://page4.auctions.yahoo.co.jp/jp/auction/d56012483
How much will that be approx. in Australia? :)
https://www.sau.com.au/forums/topic/93617-tail-light-help/#findComment-1692177
nah thats different darrin .... but interesting none the less.
I'm starting to think these may be a custom jobbie ..... which means it looks like l might have to get myself a set of s1 inner tail lights and start modding.
https://www.sau.com.au/forums/topic/93617-tail-light-help/#findComment-1692889
THATS what it is!
Originally, they got shorter lights and then put the eye lids on. Look how the top cover bit and the lower dip lines up on my car, and then how they did it on the one above it!
So it seems like the german car has different rear lights, where that hyperrevs mag is just eyelids. I like that front bar...
PS, where the hell did you get that magazine, i need to get myself a copy!!!!111!1oneone
https://www.sau.com.au/forums/topic/93617-tail-light-help/#findComment-1729971
wow!!!
Might make some calls and see if l can get them, and how much their going to cost me!! They look wicked!! :D:)
Do they have further details on the company in the book, maybe a website and an email address??
EDIT: Company is called QUEST, kit is called Include. So if l get some email details l'll be finding out about shipping as l've been told they ship o/s too!! :) WOOT!!
Edited by [ STAGEN ]
https://www.sau.com.au/forums/topic/93617-tail-light-help/#findComment-1731420
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
