  • Replies 220
cant u fit a greddy intake plenum on a neo?
those are really good ;o
im gettting on soon (waiting for greenline to reply to my email :))
He can't. He wants to keep pussy mode available (traction control). It gets removed if he puts a greddy plenum on it.
:lol: :D
Wilch
That is the best pic i have of the car to date - thanks sooooo much  :(
Its the new desktop for the computer
Again, thanks
No probs dude. Saw your car there and thought it looked like a decent shot. :)
You guys are slack.... why the lack of photos of the film car?  :(  Just because it's not a Skyline :P
I tried to get one, but was asked to put my camera down... :) :)
