Meeting Point: Speers Point Park
Destination: Soldiers Point Marina for BBQ lunch....car park at the marina
then return to Bar Beach Carpark to meet with Sydney Guys.
When: Sunday 18th December
Time: Meet up at 9.00am...leave 9.30am
Hi all!...Another Newy cruise has been brewing for a while now....
---(( POINT TO POINT CHRISTMAS CRUISE))---
It's on this Sunday !! :)
Let me know if you are interested, and i'll add you to the list!
Attending:
01) NYL83R (Chris) Dark Grey R33 GTST +1
02) d-d (Dave) Blue R33 GTST +1
03) BOZ22N (Ryan) White R33 GTST +1
04) TWO.06L (Paul & Stacey) Silver R32 GTR and
05) Matt (dark grey/silver) R33 GTST, and
06) Josh (burgundy) R33 GTST
07) monkeykpunk (Ian) Burgandy R33 GTST +1
08) dean1285 (Dean) Black R32 GTR
09) heffo () Yellow R33 GTST +3 and
10) R31 +1
11) GTS4dood (Adam) Dark Blue R32 GTS-4 +1
12) BazaR33
13) Nismo Gtst (Joe) Dark Grey R33 GTST
14) T04GTR
15) Bake (Ryan) White R31 Excutive +4
16) E.k (Dean) Zebra Interior R31 Excutive +1
17) White R33 GTST
18) r31 executive ( guy)
19) r31 gts 1 (ben)
20) r31 gts 1 (shaun)
21) r31 silo (rob)
22) (89r31sillo) r31 s3 sillo
23) lsf_bootz (Josh) White R33 GTST +3
24) weapn (Dave) Purple R33 GTST
25) PhilGTR (Phil) Dark Grey R32 GTR
26) Adam 54 (Adam) R33 GTR, plates 2 WIN +1
27) ULOOOK (Josh and Crystal) Blue R33 GTST
28) Lenno (Mark) Dark Grey R33 GTST +2
29) Biceybro87 () Burgandy R33 GTST
30) 4playr33
Number of Cars: 30
R31=7 R32=5 R33=16 R34=0 V35=0 :)
Number of People: 52
Maybes:
KEAGLE (Karen) White (with black and purple) R33 GTST
Freeman
NXTIME
wizard2k (Josh)
r31 gts 1 (rod) maybe
r31 silo (brad) maybe
https://www.sau.com.au/forums/topic/94348-newcastle-cruise-18th-dec-sunday/
  • Replies 190
hey!
Nice to see you guys are as keen as I am! :D
Yeah BBQ sounds good, how is Nelson Bay marina these days though?
Last time I was up there it was packed cause the parking is really poo
hey!
Ive suggested Soldiers Point Marina...away from the crowds and a friend of mine runs it so we have some great photo opportunities.A Park with lots of shade and lots of parking avail. If you like Stace and I could organise the bbq on a numbers/non-profit basis....also Nelson Bay is a parking meter zone so be prepared to pay for the priviledge.....What do you guys think?
Soldiers Point Marina sounds like the goods.
The bbq idea from Paul & Stace looks to be a winner aswell in my opinion.
Ahhhhhhh the advantages of starting to plan events early! Gives us so much time to float ideas around to make this a top day!
(And we better be wearin' Santa hats too :D )
yeah, i was gunan suggest Soldiers.
I had to drive all the way up to the point today in the work truck, so I took a detor and checked stuff out.
That would be excellant Paul. Thanks for the offer.
Hello All
I'm moving down to Newi at the end of this and am keen to meet up with you guys and go for a cruise. Put me down as a maybe though as it all depends on when my car arrives and if I've found a place to live and am busy moving or any of the other million and one things that have to be done when moving state/jobs etc.
Karen
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
