Howdy ppl....
I thought i'd ask before i go and try pull everything apart:
The button lights on the left hand side of my climate control dont seem to be working. That is the MODE, A/C, "FAN", "Temp Down".
Can these lights be changed? Is it simply a matter of taking off the dash facia and then popping off the Climate Control facia?....If so, what globes/led's will i be needing?
Cheers
EDIT: Sorry its a R33 GTST
Edited by R33_STEALTH
https://www.sau.com.au/forums/topic/95065-button-lights-on-climate-control/
They can be changed - quite easily! If you remove the whole control unit, you'll find little circular plates in the back with a flat head indentation on them.
Twist these 1/4 turn anti-clockwise, and they should pop out. Each one holds a tiny globe (grain of wheat globe, is what Jaycar/DSE will know them as) and you just need to replace these.
Only prob is each globe has a blue rubber cap over them to give that blue/green tinge instead of yellow incandescent light. These get brittle with the heat of the globe over the years and will be impossible to remove intact. You might be able to get a replacement cap (hopefully silicone so they will come off next time) at the same place you get the globe.
I see.....
Except i dont get one lil bit...when you talk about the circular plates in the back....u mean actually inside the unit? So do i need to open the unit up / pull it apart?
I read the thread linked by midnight. Have just replaced the bulbs with the "grain of wheat ones from Dick Smith.
Cost was $2.50 for a pair.
1. Take the control unit out
2. Undo the two bulbs with a quarter turn
3. Unwrap the thin wire holding the bulb to the holder that makes the actual "contact"
4. Carefully push a toothpick under the blue condom and roll it around the bulb to separate the rubber from the bulb.
5. Reverse order for new bulbs.
Simple. (Although on the one pictured I left a tiny bit of the blue rubber on the old bulb. I managed to get it off completely intact with the other one.)
Look closely and you can see the wire wrapped around the base of the holder. (This is the replacement globe in place)
Enjoy!
El Bee
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
