  • Replies 93
Originally posted by darK
and whats that?
Cut Rice with yummy Marinated Pork Chop with Dried shredded Pork skin marinated with a yummy delicous quiche topped up with Nuoc Mam.
I promise you its easy even for a Anglo Taste Bud :D
Its is yummy!!!
Tell your viet friends
https://www.sau.com.au/forums/topic/9509-saw-sxy-25t/page/3/#findComment-144277
Originally posted by UR2EZ
mmmmmmm samosa.... yummy
you understand the taste of the samosa..
mmmmmmmmmmmmmmmmm
deep fried by 'moia'
Originally posted by DR GTR
I love Curry.
Inasnt my buddy is a curry too!
get him to eat some Viet Food.
will do.. lol
https://www.sau.com.au/forums/topic/9509-saw-sxy-25t/page/3/#findComment-144306
Originally posted by GOLD^MemBeR
hahaha.....dont underestimate his 4wd sr20det....
its got sum guts
hahahah you mean FWD then it hooks up the rwd.
It might as well be a FWD pulsar hahaha.
The car looks like a warped Jelly Bean.
And what about mynas BF? hahaha SXY-33T ?
Pfft how original hahaha
https://www.sau.com.au/forums/topic/9509-saw-sxy-25t/page/3/#findComment-144308
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
