while driving yesterday up the high way, my car suddenly shuttered, and pooof, a big black cloud of smoke shot out behind me, then all seemed fine, but once taking of again i wasnt blowing smoke, wasnt shuttering, but on boost the turbo would spool up as usuall, then once about 2-3k rpm the turbo spool just goes nuts, its still a smooth ride but the sound is like the turbs is gonna spin itsself inside out..
now i have a faulty silicone joiner on the i/c piping, could this of just busted??
maybe a dead gasket,
or am i going to have to burry my turbo
cheers guys
cheers guys, now the hunt for it :P
ok i poped the hood and found the internal gate had a hose blown of it.. the hose feed back to the hks ebc black box thing in the hook.. would this of caused the big smoke puff and dodgy spool up... btw i cant drive it as my dash is out :) just wana know if this could of caused it
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
