With replacing your injectors with larger ones, what do you plan to use to tune them? Does anybody know if you can get your stock ecu remapped - and if their is any downloadable 'tuning' programs you can use with the skylines? I know honda you can tune the ecu yourself with hondata. or urberdata...
Dayne
https://www.sau.com.au/forums/topic/96928-which-one/#findComment-1758940
hey b-man long time no hear .
yeah been busy with other stuff work wise etc.
which state are you in Lo r33.
the rb25de has smaller injectors than the rb25det.
the e-mange is ok. re remapping the rb25not atm but dr-drift in melbourne is looking into it he can actually get an r33 to run ith a stock rb20 ecu for more info http;//www.dr-drift.com
jsut dont forget when you do the turbo conversion to retart the timing quite a bit initally.
cheers
https://www.sau.com.au/forums/topic/96928-which-one/#findComment-1759610
Im located in canberra, i have an rb20e skyline - wasnt planning on anything just curious as to how people go about re-mapping stock ecus (like they can do to hondas). Though if i turbo'd the engine before upgrading i was just curious to see what i could possibly use to tune it, so far i was thinking ecu remap, or e-manage but i dont know if they offer a harness that would adapt to the rb20e. (SOHC)
Dayne
https://www.sau.com.au/forums/topic/96928-which-one/#findComment-1760513
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
