1989 Nov R32GTR 128,000kms displayed in Immaculate Condition (Few Pin Dents)
Recently Rebuilt engine/diff
N1 Turbos
Strengthened gearbox
New Alternator
New Fuel Pump
Xenon Bulbs
Nizmo headlights
Rear Locker/lower gear ratios
H/D Clutch
Nizmo Rear Lip
Nizmo Side Skirts
Nizmo Rear Pods
Blitz Exhaust
Sard Racing Radiator With Silicone Hosing
Apexi Air Filters
Apexi AVC-R
GREX Oil Filter Re-Location kit and Remote Oil Cooler(Mounted for maxium airflow)
Bilstein Suspension Coilovers
Cross Drilled Front Rotors/DBA slotted rear rotors
Endless Blue Race Pads
Limited edition Apexi Avcr
Nizmo strut brace
Nardi steering wheel (signed by Mr Nardi)
HKS Turbo Timer
Recently Resprayed although there are some pin dents and scratches
Aftermarket BOV's
Jap Headunit
Aftermarket FIMC piping
Earth wireing kit (7kw power gain apparently)
17x9 Yokohoma Model 6 Wheels with 20mm spacers
Just had a full service
$22,000 QLD Gold Coast
Kris-0401667877 (call if interested thanks)
PICTURES CLICK HERE
https://www.sau.com.au/forums/topic/98973-for-sale-r32-gtr-modded/
  • 3 weeks later...
PRICE DROP! Must Sell
1989 Nov R32GTR 128,000kms displayed in Immaculate Condition (Few Pin Dents + Boot Holes)
Rebuilt engine/diff
N1 Turbos (no shaft play)
Aftermarket Gearbox
New Alternator
New Fuel Pump
Xenon Bulbs
Nizmo headlights
H/D Clutch
N1 Body Kit
Blitz Exhaust
Sard Alloy Racing Radiator With Silicone Hosing
Apexi Air Filters
Apexi AVC-R Limited Edition
Bilstein Lowered Coilover Suspension
Nizmo Front Strut Brace
HKS Turbo Timer
Aftermarket BOV's
Jap Headunit
20mm spacers
Just Had a Full Service
Needs New power window motor (passanger side)
I have had this car for 6 months now and have never had any problems with it
Item Condition: Immaculate
Price and Payment Conditions: $23000 ONO NOW $20,000 Firm!
Email me if interested : [email protected]
Contact Details:0755788143 or 0401667877
Edited by l005e
DAMN
I thought this was sold already?
This is the one with a front LSD and Straight Cut Box huh?
How could your of not sold this yet?
If i had the cash i would ask if u wanted to trade plus cash!
How much power is it making?
Good luck with the sale dude!
  • 5 weeks later...
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
