Item: Heat Sheild for POD and uses factory snorkal, to suit R33 GTS-T
Item Condition: Brand New
Reason for Selling: Already made myself one
Price and Payment Conditions: $120 includes regualr postage within australia
Contact Details: PM me and take it from there
I will supply the 6 pop rivets needed to put this together and 2 screws for the lid (plus a couple of spares). All that is needed it a pop rivet gun and a screw driver to fit this.
Also i will send instructions to make this easier, but its straight foward.
NOTE: i have put a sticker on my heat sheild, but i will not be supplying them.
These are the 3 panels and lid. (there is a protective coat on the lid below, it just peels off)
Edited by mr_crust
https://www.sau.com.au/forums/topic/100082-heat-sheild/
  • Replies 116
Hi there is the heat shield which uses the factory snorkel still for sale??? If so im interested but want to know something. Do I need to drill in to the chassis of the car to install or it is like a full replacement of the factory airbox and you just screw it in to the factory position.
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1845201
Sold my last one...can get more within the week if anyone still wants one.
as for the r33, it uses the factory snorkel.. and no this is no drilling required it uses the factory airbox screws, so its a total replacement to suit a pod filter
it doesnt fit a r32, as far as i know, but i've never seen an r32 engine bay
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1858990
i have got a few more heat shields if anyone is intrested, they are the same as the pics, except fot the lid doesnt have a clear lid, its aliminium.
they will be ready mid next week.
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1876115
im highly interested man..
Will u be making more of these in a weeks time or something?? im going away on holidays next week so once i come back i will order one maybe..
Whats the price difference between clear n aliminium one??
cheers..
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1882654
yeah their will be a gap if u dont have a snorkal, for me to make a new one up without a snorkal, means i have to make all new templates and measure it all up again, so im only making these ones.
they are the same price..the clear ones are sold out, ive got one left, which is pending payment, the rest are aliminium lids.
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1884297
  • 3 weeks later...
hmm mr_crust, pm your details(bank)...
Might transfer some funds in tomorrow or thursday..
interested in aliminium one.. n this will fit the snorkle right?? so its got a hole already on the side for it??
Cheers..
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1947718
Does it make much of a sound difference to a stock GTST, ive herd by adding a pod u will her the turbo suck much louder, but the pods in a box so im askign from you personal experence does it make much of a sound difference.
And secondly does this mean if a cop pops the hood its rendered "legal" ???? cause the pod is boxed???
Thanks Michael
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1949142
yup since its boxed, it is said to be legal..
You can still hear induction noise once its inclosed in the box..It will be even louder, once you finish your whole exhaust tho..
since this is a technically a box, it should be legal, ive never had an issue and the ones ive sold, ive never heard the msay they have had any issues.
once boxed it will be ever so slightly deeper in sound, but it mainly blocks of the heat and allows the pod to suck in cold clean air
https://www.sau.com.au/forums/topic/100082-heat-sheild/#findComment-1950017
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
