1997 Nissan Stagea RS FOUR 2.5L RB25DET
Brisbane
Excellent Condition
Reason for Selling:Career change will be studying in 2006
$21000
Loads of Extras
Top of the line Viper Alarm with extra microwave sensors and siren, remote start (cost $1600 installed)
Pioneer sound system CD/MP3 colour screen, amp, Kevlar splits and Kevlar speakers in rear doors, 1000W JBL Sub (over $2000 spent on sound system)
R34 GTT Side mount intercooler – slightly bigger than stock side mount intercooler
HKS Turbo timer
Digital Fuel and Digital Boost controller
Dual Sunroof
Dual SRS Airbags
Power Mirrors
Power windows
Power Sun Roofs
Power Steering
AWD
Air Conditioning with climate control – just been regased
Alloy Wheels
Automatic
DayZ body Kit with G-Squar F-line Front bar
Colour coded sides and bumpers as originals have black strips
Personal Plates not included sorry
Sad to have to sell this great car but will be studying full time in (2006) so will no longer be able to work full time.
Phone: 0421597825 or send a PM
Hey mate, Car looks good, but i feel a little over priced given the current market, once my skyline sale is all sorted out i might be able to offer around 17, depends on my sale price
If I was to sell at a lower price I would work out a lower price with a bacis sound system installed and the good one taken out.
Let me know when you sell the skyline. Your welcome to come and inspect.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
