Heya,
1995 Black Manual Model, regularly serviced at respected workshops ( XSpeed,SST,Hyperdrive Motorsport)
Mods include:
Turbo back HKS exhaust
HKS Air Pod
HKS Turbo Timer
HKS Type S Intercooler kit
Apexi AVC-R
Apexi SAFC II
Heavy Duty Clutch
Front and Rear Strut Tower Bars
Top of the line Alarm/Immobiliser
GTR Rear Wing
Nismo front spoiler
Sideskirts
17" 5 Spoke rims
Illuminous Dash Guages
Alpine CD Player
Dyno'ed at SST resulting in 302rwhp / 295rwhp at Hyperdrive Motorsport.
Recently Serviced,Dyno'd and new tyres all round...
More than happy to answer any queries as I may have left out some obvious details that I cant think of right now...
Looking for $21,000 ono
Thanks
post-232-1136124534.jpgpost-232-1136124498.jpgpost-232-1136124453.jpgpost-232-1136124559.jpgpost-232-1136124593.jpgpost-3069-1124344617.jpgpost-232-1136124654.jpgpost-232-1136124685.jpg
https://www.sau.com.au/forums/topic/100297-fs-1995-r33-gtst/
Car has done 118km's...I dont have a pic of the engine bay, but if your keen then i could get a pic for you...I can assure you its in pretty good nick though.
Heya,
Just to clarify Wildcat here is my otherhalf (perhaps betterhalf :P ). The car has done approx 118 thousand K'ms. But at least they are genuine unlike some others that may or may not be wound back.... ;)
And yeah I could organise some pics if they are needed but the car is in pretty good nick as I would say most W.A Members would attest too...
  • 4 weeks later...
Okay just bought ourselves a new stagea... so the skylines really got to go.... come on guys and gals this is a genuinly good condition car at a pretty decent price..... How can you say no??? :P
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
