simon - i preloaded the springs a little more, not much just a tad on the front.
also clicks are about 2 from full stiff rear and about 6 from full stiff (i think 7 is half way) at the front...
definitely adjusting rear damper from soft - hard notice a massive difference in grip/slip
hhmmmm konect - post up some vids ey? :( lol
  • Replies 285
Posted Images
I've got HSD's as well. had them for over a year now. Really happy with them. Only complaints are that my left front has a small leak (out of warrenty now) and i think the fronts are a little under dampened for the 8kg springs. You can feel the front bouncing up and down, it just can't handle it. This is on the softest setting btw, which is what i use for the street, if you stiffen the dampening a bit it improves a little, but then you need a new back after a while. This is why i'm going to buy a set of softer springs for them for the street. Eventually i'll get them re-valved with better dampening.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
