My couson is in japan right now.. and i can get these for less anyway without a group buy...................................................................
And that helps everyone else how?
I have a nismo 2 way gt pro in my car atm. It does clunk, but remember if you push the clutch in it stops the clunking/squeeling and just free rolls like a std diff does.
It is one of the best mods i did to my car. Power gets down a lot better. It is more noticeable under accelleration through a corner, and makes the rear heaps more predictable when it decides to step out. It wont hurt driveshafts.
Only time its ever been scary was when i first got it and was geting used to it. You need to remeber the arse will step out if you have to do an emergency brake, but keep it in mind, and push the clutch in if you ever get into a situation where u have to brake hard (which you have to do if you're coming to a stop anyway) and you wont have any problems....
  • Replies 45
WHY DOES IT HELP?
I thought group buys are ment to be non profit organisations...
hence, i can get them cheaper from my couson.....................
ISNT THIS A GOOD THING?
it MAY be good but how would we trust an $XXX amount of cash with u. you have only been a member for only 2 weeks
just my 2 cents
ITS A COMPANY..............
HEH, ATLEAST YOU GUYS DIDNT BUY A BRAND NEW CUSCO RS FOR 1k deliverd :P
please read the fourm rules....
The normal rules for users of the classifieds also apply here, in other words
* There is to be no arguing on price - If you can get it cheaper elsewhere, good for you
* No trash talking in the thread - If you have a concern, pm a moderator
and start your own groupbuy thankyou :D
HEH, ATLEAST YOU GUYS DIDNT BUY A BRAND NEW CUSCO RS FOR 1k deliverd  :)
how old are u kid? 11 ..12? if u have nothin smart to say then get stuffed and go keyboard drift somewhere else. some poeple on here actually own skylines!
Please answer above question
Cheers
sorry i cant no get them for dr30 or hr31 at this time.
Im very busy at the moment so i will hold off the groupbuy for abit as, i dont want poeple to be waiting ages once they give me their money
So now.How long untill you are ready for it?
Trust33 i need to confirmed a few things with the people in japan, as with the change of the Yen the price will go up and down, so im wanting a real fix price no matter wat the exchange rate.
i should be ready end on jan, beginning on feb and the group buy will be open for 1 to 2weeks then i will place orders etc
Hey michael can you please find out what you can get for a r32 gtr rear diff and approx costing?
Cheers
i can get Kaaz (Solid and Basic) (1.5 and 2way) and Nismo GT LSD PRO TT (1.5 and 2way) for the rear of an r32 gtr (the nismo lsd is very pricey, but i will get final cost for you asap)
cheers michael :D
Guest
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
