FS: FULL SYSTEM - Subs, Amp, Splits, Head Unit, Coaxials
For Sale -
2 x 12" MTX Thunder 4000 Subwoofers (Ported 420x360x1000mm)
Clarion VNET 450 Series
Pioneer TS-C1620
Pioneer DEH-P4050 4-Channel High-Power CD/Receiver *SOLD*
Kenwood KFC-1666 Speaker Pair
Most of this gear is hardly used, if at all ...... practically new still with box, documentation etc.
Pictures of actual gear -
http://www.pbase.com/image/12015293
http://www.pbase.com/image/12015296
http://www.pbase.com/image/12015297
http://www.pbase.com/image/12015299
http://www.pbase.com/image/12015295
http://www.pbase.com/image/12015261
http://www.pbase.com/image/12015262
Pioneer TS-C1620
http://www.pbase.com/image/12015265
http://www.pbase.com/image/12015266
http://www.pbase.com/image/12015267
http://www.pbase.com/image/12015263
http://www.pbase.com/image/12015264
http://www.pbase.com/image/12015291
http://www.pbase.com/image/12015292
Few of the components are listed here with full specs, this was the system I was putting together until plans changed -
http://www.pbase.com/image/12091568
More information available at -
http://www.mtxaudio.com/
http://www.clarion.com/
http://www.pioneer-america.com/
http://www.kenwood.com/
Open to serious offers. Will update with progress of offers. Happy to seperate or sell as full system.
For more information either PM or e-mail to [email protected]
Bids now stand at -
2 x 12" MTX Thunder 4000 Subwoofers - $400.00
Clarion VNET 450 Series - $230.00
Pioneer TS-C1620 - $220.00
Pioneer DEH-P4050 - $150.00
Kenwood KFC-1666 Speaker Pair - None as yet
Not long to go ..... :D Make sure to get those bids in before 9pm EST ...
Ok guys, the Head Unit just headed out my door at $150.00 .... remaining are -
Remember, instant sale at this price (or higher as these are just the current bids) the first to pick them up gets them.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
