Like i said before : what planet have you been living on!... Cops dont make up stories : SCOFF SCOFFF SCCOCCOCOOOOOOFFFFFFFFF!!!!!!.
I got done for drink driving 6 months ago in a front wheel drive automatic ford probe. The payment officer ( i mean police officer) wrote a one page story how i drifted this car around a corner in the wet with water spraying up every where from the REAR wheels for the court case! ie it was all a made up story so that they would have an excuse to pull me over and give me the breath test! Oh yeah  i blew .173 when they brethowed me. Even if i could drift  a front wheel drive automatic probe, it would have been interesting at that blood alcohol concentration level!
What i want to know is what was the coppers blood alcohol concentreation level to come up with such a bullshit story!!!!!!!!
hope the dick got fired!!!! Hell if i was his boss i would fire him on the spot!!
If i was a dreg of society i am sure that the story compiled by the copper would have been far worse!!!!!!
Anmyway alls well that ends well: got the minimum fine and disqual!
And i am defenitely getting my 900 bucks worth from the states roads!!!
SA traffic cops are DICKSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and they will reap what they SEW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:angry:
Let me get this straight - you got caught drink driving and you were more than 3 times over the limit and somehow the cops are dicks.......Ok....yep..hmmmm... :)
https://www.sau.com.au/forums/topic/101534-hoons/page/2/#findComment-1872476
REdgtst that has to be the appaling post i've ever seen on SAU in the 2 and a bit years i've been on here.
vote for ban. i'm being serious too. that shit you wrote brings the whole car enthusast scene down a level and justifies police targeting young males.
Edited by The_Paladin
https://www.sau.com.au/forums/topic/101534-hoons/page/2/#findComment-1872838
arkon, yep i have heard lots about grammar, and police that havnt spelt things properly.
There was one incident with an officer who was asked to spell a particular word significant to radar devices. He spelt it wrong and the argument was that if he couldnt spell that then how can he use a radar device properly?
hmmm
https://www.sau.com.au/forums/topic/101534-hoons/page/2/#findComment-1873265
why "boy racers"??? what about "girl racers"?
Hahaha quiet you :D I quite like the fact that when cops see my gtr, drive like idiots to get next to me (note: swerving across 3 lanes of traffic, changing their mind and swerving back across 1 lane, then change their minds again to go next to me), and see a female driving, they just mind their own business and drive on.
Then again, most of the time I am well behaved on the streets, and when i'm not, I make damn sure it's the most appropriate place and time possible ie: out in the middle of nowhere, good visibility, roads I know well, and roads where there's very little possibility of there being any innocent bystanders that could get hurt if things went horribly wrong.
I also think at this stage triskillion, there number of guys in performance cars is still greater than the number of girls, and I don't think anywhere near as many girls have been caught misbehaving. If you don't want the police to hassle you, drive like a nanna 9 times out of 10. Don't rev you're engine past 3500rpms, don't brake hard, don't accelerate quickly, don't squeal or smoke your tyres, and don't go around corners quickly. I find if you drive in a really predictable and sensible fashion, the police don't seem to notice you as much as if you are drawing attention to yourself.....I realise that this doesn't always work and isn't always the case, but it helps.
https://www.sau.com.au/forums/topic/101534-hoons/page/2/#findComment-1874324
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
