  • Replies 90
Posted Images
R31 do u remeber talking to my Mate on sunday sumthing about sending me pics of sumthing hes was the 1 that loves R31 and DR30's hoping u remeber sumthing :P
yeh bud i think i said id send a pic of that dr30 i think is awesome. here it is
https://www.sau.com.au/forums/topic/101708-hey-all/page/5/#findComment-1967770
hi nosman. asking about $23500. old shape,tinted windows,6stack cd,all factory installed, immobilser key pad alarm keyless entry, near new tyres , 100,000 service done, new disc's, white, red and black interior aircon just under 110,000k's, unmodified,excellent condition
get him to make an offer
https://www.sau.com.au/forums/topic/101708-hey-all/page/5/#findComment-1969472
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
