CLOSING DATE OF PRE-ORDER: SAT 4 FEB 06
TO ARRIVE: ABT 8 WEEKS AFTER THE PRE-ORDER CLOSED
DEPOSIT PER SET = $500.00, INVOICE WILL BE ISSUED FOR THE DEPOSIT.
DELIVERY: FREE IF DEPOSIT IS RECEIVED BEFORE 31 JAN 06, OTHERWISE IT WILL BE BASED ON WHERE YOU LIVED, UP FROM $95.00 TO $150.00
PAYMENT METHOD: DIRECT DEPOSIT TO THE A/C BELOW
NOW OPEN, WORK CR-KAI WHEELS PREORDER BY JDM CONCEPT
WORK CR-KAI IS A ONE PIECE LIGHTWEIGHT SPECIAL CAST WHEELS (SEMI-FORGING). GENEROUSLY LIGHTER AND STRONGER THAN OTHER CAST WHEELS.
AS OFFICIAL DEALER OF WORK WHEELS FOR AUSTRALIA, WE GUARANTEE EACH OF OUR RIMS TO BE A GENUINE PRODUCT AND HAVE FULL WARRANTY TO BE FREE FROM DEFECT.
WE CAN FORWARD A COPY OF OUR CERTIFICATE OF DEALERSHIP UPON REQUEST.
***** HAVE A LOOK AT OUR FEEDBACK ON NISSAN SILVIA AND JUDGE FOR YOURSELF *****
THE PRICES OF WORK WHEELS HAS INCREASED THIS YEAR BY ABOUT $50.00 PER RIM DUE TO THE COST OF INCREASE IN METAL PRICES.
HOWEVER, WE HAVE DECIDED TO KEEP THE OLD PRICE SO THAT THE RIMS CONTINUE TO BE AFFORDABLE TO ALL ENTHUSIASTS. THAT IS A MASSIVE $200.00 SAVINGS ALREADY!!!
NOT ONLY THAT, PUT A DEPOSIT FOR THE RIMS BEFORE 31 JAN 06 AND YOU WILL RECEIVE FREE DELIVERY FOR THE RIMS TO THE VALUE UP TO $150.00.
BELOW ARE THE BREAKDOWN OF THE PRICES OF THE WHEELS, EACH AND PER SET. THIS WILL HELP THOSE WHO NEED A STAGGERED SET OF WHEELS.
AVAILABLE IN BRONZE, GUNMETAL AND WHITE (EXTRA 3 WEEKS TO MAKE)
THE OFFSET AND PCD (I.E 4 STUDS, 5 STUDS) IS YOUR CHOICE, WE CAN REQUEST WORK TO CUSTOM MADE FOR YOU. WE HAVE DONE IT BEFORE!
15 x 5.5JJ, WAS: $399.75, NOW: $349.75
15 x 7.0JJ, WAS: $424.75, NOW: $374.75
16 x 7.0JJ, WAS: $462.50, NOW: $412.50
17 x 7.0JJ, WAS: $499.75, NOW: $449.75
17 x 8.0JJ, WAS: $524.75, NOW: $474.75
17 x 9.0JJ, WAS: $537.50, NOW: $487.50
18 x 7.5JJ, WAS: $562.50, NOW: $512.50
18 x 8.5JJ, WAS: $587.50, NOW: $537.50
18 x 9.5JJ, WAS: $612.50, NOW: $562.50
OR
15 x 5.5JJ - WAS: $1,599.00 /SET, NOW: $1,399.00 /SET
15 x 7.0JJ - WAS: $1,699.00 /SET, NOW: $1,499.00 /SET
16 x 7.0JJ - WAS: $1,850.00 /SET, NOW: $1,650.00 /SET
17 x 7.0JJ - WAS: $1,999.00 /SET, NOW: $1,799.00 /SET
17 x 8.0JJ - WAS: $2,099.00 /SET, NOW: $1,899.00 /SET
17 x 9.0JJ - WAS: $2,150.00 /SET, NOW: $1,950.00 /SET
18 x 7.5JJ - WAS: $2,250.00 /SET, NOW: $2,050.00 /SET
18 x 8.5JJ - WAS: $2,350.00 /SET, NOW: $2,150.00 /SET
18 x 9.5JJ - WAS: $2,450.00 /SET, NOW: $2,250.00 /SET
WEIGHT ON EACH RIM (ESTIMATE)
15 X 5.5JJ +40, 4X100 - 6.0KG
15 X 7.0JJ +44, 4X100 - 6.7KG
16 X 7.0JJ +44, 5X100 - 6.6KG
17 X 7.0JJ +47, 5X114.3 - 8.6KG
17 X 7.0JJ +32, 5X114.3 - 8.9KG
17 X 8.0JJ +42, 5X114.3 - 9.4KG
17 X 8.0JJ +32, 5X114.3 - 9.6KG
17 X 8.0JJ +47, 5X114.3 - 9.2KG
17 X 9.0JJ +28, 5X114.3 - 9.4KG
17 X 9.0JJ +17, 5X114.3 - 9.6KG
17 X 9.0JJ +44, 5X114.3 - 9.0KG
18 X 7.5JJ +48, 5X114.3 - 10.0KG
18 X 8.5JJ +43, 5X114.3 - 10.6KG
18 X 8.5JJ +38, 5X114.3 - 10.4KG
18 X 8.5(MT)JJ +38, 5X114.3 - 10.48KG
18 X 8.5(ST)JJ +37, 5X114.3 - 10.65KG
18 X 9.5JJ +20, 5X114.3 - 11.3KG
18 X 9.5JJ +38, 5X114.3 - 11.3KG
AT THE MOMENT, WE DO NOT HAVE ANY OTHER PREORDER FOR OTHER TYPE OF WORK WHEELS YET. WE WANT TO APOLOGISE FOR THAT.
GALLERY
ONE OF OUR LAST YEAR SHIPMENTS
BRONZE COLOR
GUN-METAL COLOR
WHITE COLOR
can you source custom offset wheels in 10.5J and 11J. If not, can you get the inner and outer parts of Work Equips (its a 3 piece rim) in custom sizes?
Cheers,
Shan
Cheers,
Shan
i will check with work about it :)
Cheers,
Shan
hi mate, work cr kai doesnt have 10.5J or 11J, there are some other type that do have. it is best to email at [email protected] cos it seems to be a long discussion
leo
no worries, sending email now. Thanks for the prompt reply too.
i didnt received ur email, could u resend it again.
Majanal- PM replied. sorry abt it :P
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
