Hey all you canberra people. I might be coming down to canberra in a few weeks and I was wondering if it is still legal to buy fireworks in the ACT?
I've heard mixed reports. Some say the rule has changed. Others say it's still legal. So what's the deal?
Also, does anyone know where some good shops are?
https://www.sau.com.au/forums/topic/102932-fireworks/
last year, you needed to be 18 with proof of ACT residency.
ideally, well illegally, you could get a friend or family member to buy them for you....
best place for em is mitchell, or out at fyshwick, i remember last year it was hard to find the "good shit", was pretty small and low-fun banter.
Edited by GTS_DUY
https://www.sau.com.au/forums/topic/102932-fireworks/#findComment-1891021
It completely changed about 2 years ago. you used to need to be from interstate, as the only way they could sell them without a permit was a loophole they abused in federal law about exchange of goods between states.
now they've banned them completely except on a couple of weekends a year when you can buy them with an ACT residency, over 18 and some little 2 day permit you get from government shopfonts(i think). so if you're coming from interstate, i wouldn't hold my breath
https://www.sau.com.au/forums/topic/102932-fireworks/#findComment-1892578
As Terminal said, you can no longer come into the ACT and buy fireworks. 99% of the shops are shut for most of the year anyway.
The only weekend it is easy to buy them, is the queens bday long weekend. Any other time of the year, you need a permit.
https://www.sau.com.au/forums/topic/102932-fireworks/#findComment-1892802
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
