I was just wondering if there is anyway you can tell what model GTR or what year the an RB26DETT was built by looking at the engine alone?
is there anything in the engine number? or small differences btw R32, R33 & R34's?
also, if i put an RB26 in a 33gts-t, will there be any clutch change needed? I have a Jim Berry brass clutch in there right now (behind my RB25). will that bolt up the a RB26?
thanks for any help. Just looking into the possibility at the moment.
Berin
https://www.sau.com.au/forums/topic/103866-rb26-id/
get a 33-26 or newer Berin :P
The 32R one isnt the best with the crank issue for the oil pump, and plus they are old.
I paid 4k for a "running" one with loom, etc etc but it was far from "running" (R32 one)
Your clutch etc, all fine. No problems there at all as mine gear all bolts up to my 26 :rolleyes:
I dont think via engine number, unless maybe that FAST software or whatever it is that everyone talks about could tell you what car its from?
https://www.sau.com.au/forums/topic/103866-rb26-id/#findComment-1909668
good to hear i havent wasted money on my clutch.
also a good bit of info to look at the oil cap....something most people wouldnt know or look for.
there's a fair few RB26's from Japan that arrive here with "un-known" previous locations (32 or 33), just as engines alone.
any other info would be greatly appretiated. or any info regarding what to watch out for, tell tale signs of a high KM engine etc...
https://www.sau.com.au/forums/topic/103866-rb26-id/#findComment-1913024
well im looking into getting another 33-t with a GTR motor in it already, so trying to find out its origins...sounds and drives like a healthy motor. fingers crossed!
any idea what the safe boost limit is on a stock RB26? I know i could do a search, but i'm lazy an cant be bothered sifting through the 15-20 pages that come up after typing in RB26....
https://www.sau.com.au/forums/topic/103866-rb26-id/#findComment-1916231
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
