TSK TSK TSK.. boys u dont play aqua golf and aim for the boat... u cover a aqua ball in lighter fluid and light it then hit it :(
p0000000n!
atleast u know which ball is urs hehehe
i'd be willing to contribute $20 towards tools.. but even better idea is a universal place which has a shed where u can do some BASIC/ MINOR work. while there.. so the tools dont go anywhere..
(eg, swapping tyres for drift day)
or swaping rubber on tyres if theres a tyre machine :D
  • Replies 43
Posted Images
I love the idea but can see it getting tricky.
I'm sure everyone would go into it/use it with the best intent but that unfortunately doesn't count for much when things get broken or aren't returned on time.
What about approaching someone already operating this kind of service and seeing if they'd be happy to offer a good discount/ good terms for the club? I know Kennards does some gear - I'm sure there are others?
We get to offer some benefit for members with no risk.
Great idea Kel. I'd prefer that to be honest - I suggested an SAU library as I didn't realise Kennard et al stocked auto tools.
Nice :D
Nice :P
I'm sure I've got a brochure somewhere- will see what I can find for the AGM :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
