Item: FZR250RR
Item Condition: Used, solid, no issues.
Reason for Selling: Upgrading
Price and Payment Conditions: $3,500
Rego April 2006
Extra Info: Have been off my P's for more than a year. Haven't upgraded cause haven't really needed to and still don't. Its very quick and I can ride around with my mates on bigger bikes without being toooo far behind. So if it doesn't sell, I don't mind, just considering moving up, but I love it, so keeping it doesn't phase me at all.
Contact Details:
[email protected]
As stated. Just tossing up the option of moving up to bigger bike.
Its great being able to give big revs and a bit of a squirt without speeding.
Great on fuel.
Light and easy to handle.
Mate just bought the best bargain we could find for ZXR, my paint is better and mine runs better, so I believe is a good price.
** pics up soon **
Issues:
Not sure really, I haven't had any, I'm sure you'd find some if you look over it. Back tyre still has plenty of tread.
Newcastle buyer would be best, can always get cheap parts or accessories for locals. Mate works in large local bike shop in parts section.
Edited by psybic
https://www.sau.com.au/forums/topic/103976-fzr250rr-learner-legal/
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
