ok, got a new o2 sensor today
what readings should it be getting on the pwrfc hc?
always reads between 0 and 1 volt, what sort of values should i see at crusing?
how can i tell if my new o2 sensor is making a difference?
can i at all?
https://www.sau.com.au/forums/topic/104244-powerfc-hc-and-new-o2-sensor/
AFAIK it should be constantly bouncing around when you're not in closed loop. And it should always remain between 0 and 1v.
If you put your boot right in, it'll jump up... but generally it'll move around like a cat in a washing machine.
ok, thats totally different from mine;
perhaps sr20s o2 sensors work differently from r33 ones!
what sort of fuel economy u get thunderbolt?
i did a few coasty runs with my new o2 sensor and it doesnt seem to be any better
ill give it a few tanks of petrol though before i start worrying
My fuel economy has always been fairly good until recently.
My o2 sensor would flick 0-1v roughly once every 3/4 of a second. ~350-380km's per tank driving it fairly lightly.
Prior was ~430km's with the 3ltr or prior with the rb20det 470km's per tank when fuel economy was what I consider good.
I Replaced o2 sensor, response was slightly quicker but still hung around the .8-.9v and 0.2v for longer than I liked, it still had crappy economy.
I ripped out the injectors replaced them with gtr cleaned items that flow within 1% of each other, trimmed fuel to 58.5%. Instantly fuel economy dropped down to 11.6l/100km's. It had a slight flat/dead spot just before boost was made, as boost began being made the o2 sensor would read 1v. :S
I had all the closed loop area's tuned to as close to 14.7:1 as possible. Just out of closed loop afr's were adjusted to 13.5:1.
Zero vacuum afr's are now 13:1, as boost is starting to be made it begins to drop down in to the 12:1's.
The base map was leaned off in the closed loop areas, just out of closed loop was richened up to achieve the 13.5:1, zero vacuum and on boost afr's were leaned off.
Torque feels like its up as it drops out of closed loop but just before it begins making boost.
Accelerating is pretty much always just out of closed loop but just before boost is made.
Fuel economy has dropped down to ~10.6L/100km's... yipeeeyaaayea... :)
woah
thats a lot of tweaking
im wondering what else can cause bad fuel economy
mines been pretty bad for a while;
ive changed the throttle body (i believe im using a ford 80ml one)
would that effect fuel economy?
any other tips i can try at home to increase fuel economy, just a little?
i seem to be locked into 300k/s tank regardless of booting it or cruising
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
