sabelt 4 point harness 1994 manufactured... really good nick with sabelt shoulder pads $100 firm suit all cars pretty much
trust oil filter sandwich block with tapped sensor holes $100 firm suit sr/rb/ca
rb20det t3 turbo in very good nick no leak, shaft play is at a very minimal - normal running tolerance $220 firm
a31 hicas pump and lines $100 firm
a31/32 aircon condensor/pump/actuator (some lines included... half are cut so are useless) $80 firm
ssr reverse mesh rims 15x?? with a 0 or neg offset (running 205's with tiny bit of stretch) and 16x?? of the same style running +20 or so offset (id imagine 16x7.5 or 8 +25) full set for 1k very minimal gutter rash if any and no dents - fully balanced - $1000 nego to split into 2 pairs if someone willing to buy the other pair
a31 disc to disc rear end (will bolt into s13/r32/c33) can supply with or without tight viscous lsd - $400 or diff on its own $250 if someone wants to buy cradle for $150
black razo ball shifter - $50 firm
white razo ball shifter - $50 firm
a31 sideskirts (unsure of brand - similar to T's garage or autech - fibergrass) damaged (all in one piece just bashed and needs respray) $100 firm
any queries send pm... will accept near to original price if offer suggested
thanks guys
willing to swap also - looking for 2nd hand good condition z32 afm, ap enginerring rb20det pfc, rb26 crank and rods in good nick, blitz lm or trust air nx pod filter brand new or 2nd hand in very good nick, any ceffy bits mainly a drivers side rear window motor/scissor/mechanism/assembley doohicky
thanks again guys!
https://www.sau.com.au/forums/topic/104645-performance-bits-for-nissans/
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
