sabelt 4 point harness 1994 manufactured... really good nick with sabelt shoulder pads $100 firm suit all cars pretty much
trust oil filter sandwich block with tapped sensor holes $100 firm suit sr/rb/ca
rb20det t3 turbo in very good nick no leak, shaft play is at a very minimal - normal running tolerance $220 firm
a31 hicas pump and lines $100 firm
a31/32 aircon condensor/pump/actuator (some lines included... half are cut so are useless) $80 firm
ssr reverse mesh rims 15x?? with a 0 or neg offset (running 205's with tiny bit of stretch) and 16x?? of the same style running +20 or so offset (id imagine 16x7.5 or 8 +25) full set for 1k very minimal gutter rash if any and no dents - fully balanced - $1000 nego to split into 2 pairs if someone willing to buy the other pair
a31 disc to disc rear end (will bolt into s13/r32/c33) can supply with or without tight viscous lsd - $400 or diff on its own $250 if someone wants to buy cradle for $150
black razo ball shifter - $50 firm
white razo ball shifter - $50 firm
a31 sideskirts (unsure of brand - similar to T's garage or autech - fibergrass) damaged (all in one piece just bashed and needs respray) $100 firm
any queries send pm... will accept near to original price if offer suggested
thanks guys
willing to swap also - looking for 2nd hand good condition z32 afm, ap enginerring rb20det pfc, rb26 crank and rods in good nick, blitz lm or trust air nx pod filter brand new or 2nd hand in very good nick, any ceffy bits mainly a drivers side rear window motor/scissor/mechanism/assembley doohicky
thanks again guys!
https://www.sau.com.au/forums/topic/104645-performance-bits-for-nissans/
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
