Air shocks were screwed. Their design is you cant replace the shock, so for a 15 year old car, they were gone. Couldnt get a roady here (not dodgy) so I sold it. I was too honest about the car and only got 8k for it.
It was a nice car to drive around illegally yes :P
Looks like the my White Stagea has been sold last night
Deposit taken
Car arrives on Monday and then off to compliance
The new owners are is Adelaide, so that should make the local Stagea owners happy :laugh:
Just need to wait now for the my silver S2 Stagea to arrive, it is still sitting in some 1 horse town in Japan waiting to get in a shipped :P
Guest Miss_Nismo
shhhhh on the local front.... :D playing it quiet until we get it on the road
yeah paul wants to keep it quiet so when it arrives he can hit the town in his batman outfit and impress everyone
thanks for everything darrin! can't wait till it gets here - spewin you have to wait even longer now for you new stagea, but i'm sure it will be worth it! :drag:
shhhhh on the local front.... :ninja: playing it quiet until we get it on the road
'sif anyone from SA reads the Stagea section! :D
LOL - classic :mellow:
Looking forward to checking it out when its finally down here, well done. :)
  • 4 weeks later...
New owners are Paul and Melissa
It will be Melissa's (Miss nismo) car
They should have it in 2-3 weeks
Cheers Darrin.
The Stagea arrived in our driveway on Monday afternoon, after leaving Southport about the same time last week (apparently the transporter came across a flooded bridge and had to find another route).
I have spent the public holiday today cleaning it all up and familiarising myself with this piece of family wagon magic. The white pearl colour is simply amazing when freshly washed.
Engine runs extremely smooth and quiet, with the nismo exhaust giving only just a noticable note, fantastic.
The premium Addzest sound system sounds fantastic (Bass engine under passenger seat, and Digital sound processor under driver's).... although some of it will end up being binned (Sat Nav and TV is in Japanese and the head unit will need a FM expander). ANYBODY HAVE ANY NEED OR IDEAS ON WHAT TO DO WITH THESE COMPONENTS?
I was lucky enough to find three small tokens of the previous owner's life with the car also:
a 10 Yen coin, a Cigarette that had been dropped down the seat, and the rear ashtray was full of aqua coloured little 'pearls' (old airfresheners I assume).
Its off to vehicle inspection and ID check tomorrow and then she is on the road!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
