(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item: 15" rockford p1 in box (6 months old) 12" rockfor sub in twin box
Item Condition:excellent & good
Reason for Selling:15" is too f@cken loud and big!!! 12" box won't fit in my boot so i took 1 out and put it in a single box
Price and Payment Conditions:15" $50012" $100
Extra Info: they go hard
Contact Details: pm me :(
SOLD :mellow:
Edited by RT33
https://www.sau.com.au/forums/topic/104882-subs-for-sale/
