Camshafts
Guest Nismo_Freak
What kind of gains are seen from a bump in duration and lift?
RB26DETT
Say using the 272 duration / 10.5mm lift, w/ valve springs on a fairly standard motor using only intake, 12 psi boost, full turbo back exhaust, fmic, and a HKS AVC (the fuel controller).
I would also swap the cam gears for adjustables and go with a 4 degree retard on the exhaust with a 1 degree advance on the intake.
Assuming fuel was optimized for the added airflow and tuned properly.
https://www.sau.com.au/forums/topic/10527-camshafts/
The gains are huge, it will be one of the most important factors in getting huge horsepower. Without decent cams then the potential of any turbo is not used. I would only tend to use cams like that with a bigger turbo, but even without it a 10-15% increase in power is possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-168818
Guest Nismo_Freak
Sounds about right I suppose... the camshafts only increase the efficiency of the motor at the higher revolutions with a slight drop at lower rpms. This in turn creates lag as noted. But the end result is more power produced at lower boost levels. The requirement for octane however goes up because the dynamic compression increases, the same when boosting more. I just needed some numbers to go by. The stock cams are as follows, I believe:
Intake: 240 duration w/ .338 lift (8.58mm)
Exhaust: 236 duration w/ .326 lift (8.28mm)
The use of the cam gears will allow me to maintain the midrange and gain back some of the boost threashold lost when I moved to the hotter cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170233
The 272's will kick in at around 4000+rpm and give the motor more legs to 8000+rpm. Something around 250 or so duration would be a better choice for a streeter. I think there are a few around 254 duration.
Most aftermaket cams need to 'dialed in' according to the motor. The factory usually designs them for a 0 deg fit but, depending on what you have done they may benifit with various timing settings.ie: don't take 4 degrees as gospel if you use non factory cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170393
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
