Morning All,
Ive decided to step up the quality of my oil to redline. Ive been quoted about $125 for 5 lites of the 10W40 (engine oil) and about $65 for 2 and a half litres of the shockproof. What shockproof should i be buying tho. there are 3 grades and i got told by one guy that the "medium" would be fine, then another said the "lightweight" is what i need. Would there be much difference between them???
the mods i have are :-
Pod, Intercooler, 3" exhaust turbo back, Power Fc (about to get installed) and boost controller (shipping as we speak).
https://www.sau.com.au/forums/topic/105652-redline-oil-change/
i run the same combo ... it does deppend if its Getrag box which i beleive is later model skylines... but you didnt say what yours is bud !
for r32's i went 10/40 Engine, lightwieght shockproof like the dealer book says but for the getrag upgrade the superlighweight is used!
A tip... Anyone supplying these oils should have knowledge and manuals to follow like bursons where i went. i made him ring redline to make sure.....
Edited by ishh
Yeah im about 99% sure i dont have the Getrag box. One of the guys mentioned this to me. well, id say lightweight it is. Cheers for the help. also how often do u change the redline oil. i currently change the engine every 5,000kms. i hope to get a bit longer out of this oil for the price. is this the case or am i just pullin the old wallet out as always?
I have been using the Redline engine oil for about 5 years now on my old gtst and now my gtt. I usually change it between 5000 and 7000 kms. On my last change I thought I would take it to 10000 but for some reason my engine warning light came on at about the 9000km mark. I did a diagnostic check and came up with an 02 sensor error. I changed the 02 sensor but this did not fix the problem. I changed the engine oil and the light went away. I have no idea why I would get an 02 sensor error from old engine oil but this is enought for me to keep up the 5 - 7000km change in the future.
Also if you are buying it from an auto shop and not a mechanic, it comes by the gallon. This is not enought for the RB's, you will need to buy 2 to begin with and you should get about 4 more oil changes out of the second gallon.
Craig.
You will need around 4-5L of oil for the gearbox, ive only seen it in the 4.5-5L containers and you'll pretty much use it all.
Redline engine oil comes in per quart bottle too so you could just get the exact amount and nothing more.
Redline
i used the 3.78 litre pack and the 1 pint extra bottle for my rb26 and filter...
i have about 500ml top up if i need it :) and was around the $150 mark.... $125 for the 3.7 and $35 fore the pint
The gearbox took 1 x 3.7 litre pack of lightweight with some still left in the bottle so that 5 litre figure your guessang at benm is probably a little exessive. Dont go guessing its to important....
theres lots of info on sump capacities in the info bomb search feature.
Edited by ishh
Benm, u have a GTR but i have the GTS-4. I think we have the same gearbox from memory. not positive. if not then would that be why the guy told me i only needed 2 1/2 litres for the box. Is this what a normal R32 GTS-t box would take???
I've used the red bottle which is 3.765L in both my R32 GTR and R33 GTS-t and on both occassions their was about 1-2cm left in the bottom of the bottle, so i'd say atleast 3.5L will be needed however I have no idea about an R32 GTS-t.
I just bought 2x bottles of redline 3.87l 1030w for $120!!!
Works auto assesories in perth.
The guy told me to use 10-30w.. is this too thin?
How did you get 2 bottle for 3.87L? You mean 1 gallon for $60 bucks? That really good prices you get there.
btw Redline comes in per quart or gallon bottle.
Edited by Trex101
i checked out www.redlineoil.com.au/reseller-locations.asp and it has each dealer in each state. the "coventry auto parts" dealerships currently have it on special. i was quoted $125 for 5 litres of 10W40. similar price for the shockproof stuff, roughly $25 p/litre it works out to be.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
