Xbox With Modchip and 200gb Hard drive
-Perfect condition Xbox
-2 Controllers
-Evo X Modchip
-200gb Harddrive
-38 Games ( Most are New releases)
-Heaps of emulators on the Xbox eg : Snes , Nes, Atari , Sega
-Play any burnt game
-Play any burnt movie ( all Regions )
-Backup any Movie on HD
-Backup any Games on HD
-Backup any Music on HD
-Also comes with female to male end cables for audio output (connecting to Stereos)
Xbox Is in Perfect condition
Asking price : $400
Located in Sydney
https://www.sau.com.au/forums/topic/105680-xbox-with-modchip200gb-hd/
sorry bud cant go dat low.
$385 for u, the console is perfect wont let u down. So much hard drive room u can fill shtloads of games on. neva get bored. need to sell for car rego money. il keep ur offer in mind though thnx bud.
how much are the new xbox 360's these days ??
core packs gonna be $500 and the full pack'll be $650.
theyre gonna sell cheap though, weve got about 30 at work, were guessing theyre gonna be gone in less than 4 hours.
and were only getting enough full packs for the pre orders.
given this, its gonna be hard to sell an XBOX for more than $200.
  • 3 weeks later...
Sure 12months warranty will still be valid once you add a chip... :D
Its not a bad price for a Box with a chip in it. Who installs mod chips for $50 anyway??
It might be hard to sell a standard box for $200+, but for those that have used modded xboxes, they know the power is only unleashed once you chip it and install a decent hard drive.
XBox 360 may come down to $500 for a complete pack within 6months or 12 months, but who cares, until they have chips for them, $100 per game is gonna suck arse.
$350 with all the games you want and ability to play DIVx and all sorts of file types, use as FTP server, do what you want. its a bargain.
I might be interested in a month, I'd say it will be gone by then...
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
