thanks for that guys, im looking at skylines at the moment, though im just sorting through all the shit cars, there are so many dogs out there. Trying to find one half decent b4 i look seriously at it. will def pm/ring when im going to look into more detail at the car!
Cheers, Tyson
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1953395
Check the undercarriage for dodgies.. be careful of ones where the paint looks *too* good, as a cheap job may look good now, but in 6-12 months start bubbling up as more than likely it will be a cheap job (some dealers nearly respray all stock). It will be near 15 years old, not many cars have immaculate paint jobs by then.
Otherwise just take it for a drive, check for clunks, floaty steering, make sure the brakes pull it up well. Check for crunches in the gearbox, clutch engages freely, even tyre wear, and oil leaks, particularly under the engine (rb20's love to leak when old - and usually its a bitch to fix).
Oh, pull off some of the intercooler piping (or AFM), and check for accessive oil in there. If there is any more than a tiny amount, definitely don't buy it.
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1954442
You can check that pipe.. or main intake pipe that goes to manifold.. Basically if there is a *lot* of oil in there (as in you can see it dripping off your fingers), there is oil from the sump blowing past the piston rings during each combustion stroke. Meaning the piston rings are worn.
This pretty much means there isn't too much life left in the motor as it'll only get worse and worse until something gives way.
It can also mean that the turbo is going, letting oil into the system -- again whilst not as bad as piston rings, probably not a great thing.
Anyhow, that is my explanation... :)
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1959522
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
