To all the 4 door owners out there:
After recieving many EOIs about the 4 door cruise I have gotten off my arse and mapped it out. Thats right kiddies the details are as follows...
Date: Saturday 25th Feb
Meet Point: PM
Depart: 10am Sharp!
Destination: Find out on the day. It includes some town driving but most is country / twisties.
Layout: We will meet, cruise, meet and maybe BBQ if I get enough PM's
Bring: 4 door JAP IMPORT, ie Cefiro, Laurel, Stagea, 4 door skylines. Full tank of petrol, cash incase you want some snacks, melway and ur sensible hat :)
The map will be handed out just before we leave and there will be a $2 donation to cover map cost. It has pictures too so well worth the 2 bucks!
NB: No stupid shit on the day. I don't want a defect cruise !
Edited by konect
https://www.sau.com.au/forums/topic/105972-4-door-cruise-vic/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
