How about a graduated two colour effect with a graphic design. You could respray the top of the car something complimentary to the silver, say a deep purple, with a nice graphic along the side to form the seperation. You can respray the bonnet to match, which would give you a classy new look, without the pain of engine bay, inside of doors etc. You could cover the whole lot in clear. Some very trick custom cars have this look. B)
I was fooling around with this a while back so thought I would stir the pot with a few pics! Not fantastic but you get some idea...
Green:
Bronze:
Midnight:
Blue/Green Pearl:
Candy:
Apologies to the actual owner of this Stagea, not sure where the image came from now...
Cheers
Luke
Yep, that purple one does it for me. Mind you, they all look good. Shows what a nice beast the Stag is to work with.
If you are going to be using it as a daily driver, something like that would be good. A full custom Kandy Pearl coated number would be a mite tempting for a bogan to scratch.... ;)
that green on munchdesign's post looks hot on a stagea.
it looks like hot house green, which i was leaning towards doing.
but after seeing that picture i definately think thats the colour.
looks sweet..
Dont forget the red pinstripe either (complemantry colours), and smoked rims. Would look real nice. :P
But that blue/green pearl looks HORN! :lol:
  • 4 weeks later...
i think the red from the ba XR range is great. real bold red. and a white starsky and hutch stripe going over the plastic bit between the rear windows. it'd suit the lines perfectly.
i'm not ready for racing stipes yet though hah!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
