I have track day tomorrow so I tried to wire up a Gizzmo Tacho Recall to my R32GTR 93 Vspec.
There are only 5 wires and the instruction seems easy.
Red- ECU power
Black - ECU ground
Green- from ECU tacho
Blue - to ecu tacho
White- not used, for launch control module
The instruction that came along with it showed where the power, ground and tacho pins are in the rb26dett. The power and ground are spot on. RPM is on pin 7. Checked the manual and sure that is the tacho speed signal. I sliced this and connect the Gizzo in series according to the instruction ie green to ecu and blue to tacho.
I started the car and the unit does it's rountine flash thing. Started the car and the tacho works fine. I pressed the 2 buttons on teh gizzmo unit, as instructed, nothing happen. I rechecked the wire and then even swop them around and still could not adjust the unit. Could it be faulty?
So I disconnected the unit. Left wirefrom pin 7 disconnected and started the car. It idled and rev fine. The tacho still work as normal :domokun: So I resoldered pin 7. :confused:
Is wire 7 the tachometer drive signal? Has my car got some different wiring system for the tachometer?
Has anyone installed the Gizzmo tachoshift recall? What pin did you use?
Many thanks in advance.
Edited by 9krpm
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
