Hi guys,
I sold my S1 R33 a few months ago and got a stock run around car. I cant stand it!
So ill be in the market for another sports car very shortly.
Im having a look at a nice white SII this weekend, But would like to see what else is out there,
So, Private/Importers. If you know of anything decent, let me know.
Essentials,
SII
5 Speed
Under 80,000KM
White, Black or Silver is my pref be will consider others.
I like fairly stock looking skylines, No huge bodykits..etc,
Some decent sideskirts and rear pods is nice tho.
I like the stock, but dumped on 19"s look also.
Engine mods doesnt matter, As i will want to get my car to pump out around 240KW ATW once done.
Also, I have a 99' Dawoo Lanos and a 99' GSXR road bike up forsale currently, So if someone would like a swap for a big road bike or a daily i could arange something + cash. (If not, Im looking to spend between 16-20k)
Cheers
https://www.sau.com.au/forums/topic/107339-wtd-r33-gtst-sii-5-speed-syd/
Hi guys,
Essentials,
SII
5 Speed
Under 80,000KM
Cheers
I have a R33 for sale in whole cars. The link is http://www.skylinesaustralia.com/forums/in...howtopic=106972
Cheers
i have a silver s2 for sale (buying gtr)
1st aus owner
well maintained
84000kms
factory sun roof
factory rear strut brace
front mount
exhaust 5zigen
system
excedy heavy duty clutch
pod
spotless interier
alarm
t/timmer
tinted windows
paul
0414690083
north sydney
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
