Hi Everyone,
I've noticed that when i hit above 100kph and brake lightly, my steering wheel starts to shake abit. Before i got my front rotors machined it was shaking real violently. I have also noticed that my car does drift to the left quite often especially when on high speeds. All wheels have been balanced and aligned.
Has anyone experienced these symptoms in the past? any help would be great.
Cheers
Mark
https://www.sau.com.au/forums/topic/107398-steering-feels-abit-off/
Hi Everyone,
Cheers
Mark
hey mate, mine does the same thing, my mate reckons its cos the rotors might be warped and on their way out. And also since i got adjustable castor rods the other day my steering shakes a lot more now at around 100+km/h, but the weird thing is it seems like it depends on the surface of the road?
Maybe the castor and camber setting is too agressive? I don't get shakes or anything in my Silvia but I do notice it tends to follow the camber of the road more than it used to. It sits perfectly straight on a flat road though.
There are a bunch of bushes in your steering system that could be worn. You need to jack the car up and get in there with a tyre lever or something like that to look for any excess movement.
On the R31's the steering rack mounting bushes go on them causing a similar thing to this.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
