Car looks dirty at the moment, just gave it a good wash yesterday. will try to get new pictures posted up Asap.
Lows_13: its the exhaust only
forgot to mention that the HICAS has been locked out
Edited by OutoftheblueR32
https://www.sau.com.au/forums/topic/107655-pls-delete-me/#findComment-1990364
hey brother nice i love the color
truth is if got the money but it worrys me that its in SA and im in QLD
is the price with roady cause it wouldnt be valid for me just wondering how neg u r.
can i also see some interior pics.
email...... [email protected]
https://www.sau.com.au/forums/topic/107655-pls-delete-me/#findComment-1998852
yeah the rego runs out in May.
anyway as promised interior pictures are up. Let me know if u guys want to see more pics.
https://www.sau.com.au/forums/topic/107655-pls-delete-me/#findComment-2000033
When was the paint done, and who did it?
how far back do you have receipts for servicing? did you do it or someone else?
Thanks
the paint was probably done by the last owner. reciepts date back to last april if i remember off from the top of my head. i had the car for a year. servicing was done by a proper mechanic. needs to be sold because i'm running low on cash.
https://www.sau.com.au/forums/topic/107655-pls-delete-me/#findComment-2057041
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
