Need Muffler Advice please.
Guest Nightsky
I am searching for a muffler for my car. The basic idea is to have it as quiet as possible, while losing the least amount of power.
At the moment the exhaust is 3 inch turbo back to the resonator at the rear. This made 100db which needs to come down at least 10dbs and hopefully a fair bit more.
I have heard of a few high flowing mufflers but dont know which ones to choose.....
Any recommendations please?
https://www.sau.com.au/forums/topic/10776-need-muffler-advice-please/
Nightsky: Ring Lambros at Hi tech Darlinghurst on 9332 3524 tell him you spoke to me and let him know what you need. He will tell you whats required. My 200sx was 115db and he sorted it out nicely so it passed an EPA inspection.
hehe, where to start? A silencer will help u pass inspections and get it nearly as quiet as stock, although i hear theres a new rule about them having to be welded in?
I had an idea to use 2 big resonators and a straight thru rear muffler, it will look funny but its an idea.
zman: it'll take me 2secs and a spanner to get that silencer out.....no one is safe! :lol:
Originally posted by cereal
Nah....only TWS know all about the ins & outs of a good, sexy muffler.
This was the best place to post by far......Frank & Loz will be able to give you their recommendations from hours & hours of extensive "research".....
gimme 1 hours and i would have completed my "DEEP REASEARCH"
give loz 1 week and he would have just barely scraped the surface of his :)
hahahahahahahaaa
LOZ WEARS SHORT SHORTS !!!!
serious note: im interested to know where u can buy silencers from ??? when i got mine it didnt come with one bu there is a screw hold for one to fit in...
Guest Nightsky
Loz: I heard the same thing about having to weld silencers in..... not sure though.
UR2EZ: You can get silencers from most exhaust shops. I'm fairly sure Liverpool exhaust has them.
Zman: Yep thats it. I think its a roughly the same diameter as a pea shooter that runs inside the length of your muffler bypassing the actuall resonator/muffler if thats what the term is.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
