Did anyone know that there are Undercover cops driving a unmarked WRX around?!? I saw one this morning on the parkway, two cops dressed casual driving a dark blue WRX, sirens on the bumper flashed blue/red alternately ( I only saw a glimps) pulled over this other Rex. I know that there is a white WRX police car but didn't know that there is a unmarked one. Anyway just warning people....
https://www.sau.com.au/forums/topic/10778-wrx-cops/
Yepp, and there's a black unmarked 2001 model WRX going around too.
It has mega dark tinted windows. I saw him pull over a car that went through a red light at the Woden Hospital lights.
The WRX had the normal red and blue flashing lights in the back window.
You've really got to watch out these days, they're everywhere :D
J
https://www.sau.com.au/forums/topic/10778-wrx-cops/#findComment-175836
Next time anyone sees one, write it down so we can get a little "list" going of the plates :)
eliteopps: good point about the tints! one rule for them and another for us hey! I got followed by a cop car but i didn't think it could be one cos one of the front headlights were blown. i was gonna tell him when he pulled me over, but i didn't want to push my luck hehe.. Is a blown headlight an offence? ;)
https://www.sau.com.au/forums/topic/10778-wrx-cops/#findComment-177482
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
