hey .. i am over in adelaide for a few days ....
Last night I had a slight accident in the r32 gtr which Transport SA will be footing the bill for ....
i need as the title says the steal mounting bar and front spoiler assembly ...
Im not to familular with adelaide and wondering if someone can direct me to a skyline parts place
or a place to order .. thanks
https://www.sau.com.au/forums/topic/108568-r32-front-bumper/
You can try Import Spares on 82660212 they might help
