I have sold my car so i now have no need for this turbo which i purchased last year.
The Turbo is an HKS T3G, which is what HKS now call the 25-30.
I am pretty sure it 350hp,(So good for 200-230rwkw)
It is based on the Garrett T28, as most of the HKS bolt on range are. (oil and water cooled)
Turbo has been freshly rebuilt, and has not been used since rebuild.
Lines and fittings are included, including a 3" Dump pipe, Braided oil line, water line banjoe bolts and the oil return line, with gasket, fittings and bolts.
So basically everything needed to bolt this turbo straight up to an rb20-25.
Im am asking 1100ono and would preffer a Melbourne buyer,
Thanks
Blair
0411 289 930
hey mate, is this turbo roller bearing?
Thanks, Mike.
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2000747
I gaurantee it has not been rubbing on the housing, Has not been used since rebuild and balance...
It is the light in the picture reflecting of some blades but not the others,
The black stuff on them is a bit of residue off the tape i have covering the housing. Part cleaner, or the turbo in action will blast that right off...
Yeah, I think you'll find the shaved section - or the bit on the wheel that looks like it has been rubbing - is actually the balancing marks. They shave tiny amounts off the turbine wheels to make sure they are properly balanced - this is perfectly normal.
Where abouts are you located?
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2032691
  • 3 weeks later...
how many kms ahs this turbo done, how laggy is it, and where is the power band? any shaftplay? and can u run this without ecu and injectors so long as u running standard boost, as a temporary thing?
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2128025
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
