Hey mate
Interested in the turbo
Is it still up for sale?
Also do you know what is the maximum psi the turbo can run?
I have an rb20
I an currently running a r33 trubo on 15 psi and i got a 13.7 1/4 mile
I now need a bigger turbo to run around 18-20 psi
Thanks
https://www.sau.com.au/forums/topic/108588-sold/page/2/#findComment-2164424
