does anyone know how to setup a mic? my mic was working fine until i did something and it ferkd it up, so now weneva i record or talk over the mic everyone can hear what im hearing through my headphones when they shouldnt be. help please >.<
yeah I wouldnt bother with quad cards. but two in sli would be nice.
jsut want to play crysis with nice frame rates.
call of duty already looks nice on the 8600gt. but It would look alot better with high resolution.
Almost better off selling the 8600gt and buying one 8800gt as one 8800gt kicks an sli 8600gt setup.
all the nohaxnetwork servers are good
my name is MR.MADAz
you can find me in NohaxNetworks Ventrilo
IP: 144.140.154.69 PORT: 3875
you will need to right click my name and send user page and i will hear you
i also play alot of SOF2 on PTGN Perth
i use the Arena to find my games :( i have Xfire but dont use it
my name is MR.MADAz
cool.
Been playin it on ps3 alot.
just started online with the pc. So alittle shit.
Will see you on there im sure.
I've played a bit of COD4. usually on the Internode servers. Apart from getting my arse handed to me they appear to be fine.
Recently bought a 22" samsung and the ol' 8600GT is struggling a tad at 1680x1050. Still does 'ok' though doesn't completely fall to its knees.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
