ahahahahaha!!!! :laughing-smiley-014:
i cant, her boy friend is there lol
sorry, back on geek topic.
LOL i think steve was talking about YOUR girlfriend not the next door neighbour, but whatever floats your boat. i wish i had hot neighbours :thumbsup:
oh oh gotta keep it computery. i got a Compaq Presario, 526 meg of ram, its ok for what i use it for. sau, myspace, porn, msn.
i guess there is that option go next door and look @ your girl through the windows, :) will seem like your being naughty :thumbsup:
LOL i think steve was talking about YOUR girlfriend not the next door neighbour, but whatever floats your boat. i wish i had hot neighbours :)
Whhoo my turn now, my turn now!!!
My main rig that I build at the beginning of the year.
Intel Q6600
Gigabyte P35 DS3P
2gig DDR 800mhz @ 4-4-4-12 timing
2x 500Gb WD SATA II
1x 200Gb Seagate SATA (from old com)
Pioneer & LG DVD writers (LG is from old com)
512mb G92 8800GTS
500w super flower PSU with TT Soprano case (from old com)
Zalman CNP 9700 LED CPU cooler
19" Samsung LCD (from my old com)
+ some random tri colour neon :thumbsup:
My laptop:
Asus M50sv
Intel C2D T9300
2gig DDR 667mhz Ram
250Gb SATA II
Geforce 9500m GS video chip
15.4" WS LCD
+ some external USB TV tunner
Whats a good racing game to try out? I'm up for ideas for both arcade or sim (got an old Logitech momo wheel).
damo love the porn in there!
oh i have a new hp eepc!
woot!
GRID has some good drifting in it
are there any good Lappy's to play a Q3 engined game while im on lunch and browse the net not having to use my phone
...My laptop:
Asus M50sv
Intel C2D T9300
2gig DDR 667mhz Ram
250Gb SATA II
15.4" WS LCD
Hungry Vista. :D
Idling. ~1.08gb
With BF2 running MP Small Map Wake ~1.6gb
and WinXP Pro under Vmware; all though it doesn't have the usual Bitdefender, daemon tools and msn running of which soaks up maybe 100mb.
XP uses bugger all. ~300mb.
My turn methinks...
Gigabyte K8 Triton
Thermaltake Soprano Case
AMD Athlon 64 3500+
2 GB RAM (4x 512MB, running in dual-mode)
NVIDIA 7300 GT
2x 160 GB IDE Internal Hard Drives, 1x 320 BG External Hard Drive (I just got rid of aN 80 GB IDE Interal Disk, looking to by a 500 GB SATA Drive in the near future)
Logitech 5.1 Surround Sound Speakers
Logitech Wireless Keyboard & Mouse
HP Photosmart C3100 Series (Print/Scan/Copy)
Dvico FusionHDTV Pro (2007)
DVD Burner
17" LG Flatron
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
