Just got my Creative X-fi extreme audio sound card. having probs installing.
Comp wont even detect the soundcard for some reason.
Win Xp.
anyone used these cards before ?
no diff between PCI 2.1 slot and normal pci and pci E ?
Win Xp.
I've got the Creative X-FI Fatal1ty champion series , probably the same...
make sure you have power plugged into the back of the card , if thats in and its still not detecting , try a different slot.
have you disabled onboard audio via bios ?
Ive disabled via system devices etc. Might be something to do with the slot on the motherboard.
Tried other pci slot and nothing comes on the screen.
Will try disabling via BIOS
Shouldn't matter if the onboard is not disabled in BIOS because you should be able to switch between devices in Control Panel.
Just double check that it's seated correctly in the slot
As I stated above I was trying to install my new soundcard. So I can have some crisp sounds for music production.
after about 234 hours of stuffing around I became impatient.
Tried clipping what I thought was alittle power supply to the end of the soundcard. did this while the comp had power. Screen went all funny so i switched it of quickly.
Now when I turn it on I hear all the right sounds but have absoloute nothingness on the screen.
lost some music and im going to cry alitte bit.
its not likely you've lost your data
reset the CMOS, you may have only screwed the bios settings
-D
Will try that.
Just dont want to go near the other comp for a few mins. It may end up on the road or in the oven.
I was looking around for maybe a small fuse I may have blown ? Dont some motherboards have em ?
OK so you hear a single beep when you turn the machine on and you get fans/hdd's spinning but nothing on your monitor.... At worst you've fried the graphics card. If nothing is happening (after what SLED has already advised) then you might have fried the Power Supply. Having re-read your post ^, there is a difference between PCI Express and PCI 2.1. PCI 2.1 slots are usually white slots on mobos and have a largish edge connector, most if not all PCI cards are compliant with 2.1. PCI Express cards have a very short edge connector and slots are usually black.
Also if you ever need any help/advise in regards to computer music production feel free to PM me... I've been doing this stuff for far too many years and have built and configured many digital audio workstations. If you don't mind me asking, how much did you pay for the creative card?
Still nothing.
hmm'''
I took out the Video card and went to onboard. Still nothing. so its not the gpu.
How exactly do you reset CMOS> maybe im doing something wrong.
I install all my own parts and never had this prob. its fkn annoying.
There will be a jumper switch located near the CMOS battery or between the pci slots - your motherboard manual schematic will point u in the right direction
download it off the net if u havent got a hardcopy
simply move the switch from position one to position two and back (while the unit is off)
same goes with jumper pins and jumpers, it'll be located near the cmos battery
yes there are fuses, but theyre located inside the power supply - i dont recommend you open that up due to the capacitance and AC current
-D
Easiest way to reset the CMOS is just to pull that button battery out from the mobo & leave it out for a bit & put then put the battery back in, that should clear up what ever settings were stored.
Alternatively depending on your mobo model, there is a specific jumper pin you have to set to reset the CMOS (have to read your mobo instruction manual for that). Some of the higher end spec mobos have a switch/button for it, instead of a jumper.
Good luck with it.
On a different topic, my GTX-260+ card just arrived in post today :D
EDIT: got beaten to it.
Edited by Mayuri Krab
Intersting. Usually when something like this happens at the end I always think Ive learnt something.
Tonight I havent.
Put the 9800gt gpu back in. Nothing.
Tried cmos battery method again. nothing.
Tried cmos jumpers. nothing.
I just cant put my finger on it.
That last screen I saw b4 all this happened did look pretty scary. Prolly fried something .
I even Tried clicking mouse buttons etc while the thing was running just to hear the HD running thru cycles. nothing again.
Tonight I havent.
well start with the obvious. change the power supply unit to another one, if its a matter of voltage regulation or fuses you'll know straight away...
next thing would be your motherboard but you'd have to find a place that has a spare thats compatible with your cpu and ram to eliminate that variable.
-D
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
