My work laptop (this one I'm on now) randomally without warning does weird shit where the screen goes either black or pink and I lose whatever I might have been working on. Have to force off and reboot and then it works again.
help desk just had my reseat the RAM. still no worky. see what they come up with next.
SO, i connected a secondary screen and ran Primary Hard Disk Self Test, results are "#2 - 07 Fail". HP tells me i need to purchase a new hard drive. I dont see how that affects my display tho?
Can you access anything on the drive, I'm assuming you can because you ran the disk test? With the second screen plugged in can you access Windows or is it not booting from the drive at all?
If so I'd get any or all data off of it while you still can.
Ok so i managed to ferry files from my laptop to work pc via USB. Looking at HDD's, Western Digital 2.5" 250G, $88 from MSY. is this what i need?
yeah but make sure you get the right one (IDE or SATA)
If you're going for a new HDD, get one with high rpm (7200 minimum) you'll notice a huge performance gain on the 5200 rpm drives. Get a Solid state drive if you can afford it. They have the best performance but they are rather expensive unfortunately...
-D
EDIT - I still cant fathom why a hard drive fault would cause your screen to stop working... I smell shenanigans
Edited by Dohmar
RE: your Edit: thats what i was thinking, i asked this from HP help, and they said the OS might control the video... pretty open ended answer. My comp still seems to work fine, maybe ill run Preimary Disk check again to double check.
thats bullshit
the BIOS controls the video until the operating systems driver overrides it. call them up again, cut sick and demand that you speak to someone who isnt incompetent
-D
i got this email back from them:
Hello Damien,
Thank you for contacting HP e-Solutions.
This e-mail is with reference to Service Incident id: 1953674 for Compaq Presario C554TU Notebook PC.
I understand that the display is very dim, but there is display on an external monitor. Also, the hard drive failed the test from BIOS with completion code 7.
The notebook needs to be repaired to resolve the issue. Our records show that the warranty of the notebook expired on 26 Apr 2008 and hence the service is chargeable.
Please provide the following details to setup a service event:.................
So i said:
Hello,
So all I need is a replacement Hard Disk Drive? Or is the screen a different issue?
Reply:
The issue with the dim display can be resolved only by replacing the display panel as there is display in external monitor, but very dim display on the notebook.
Please e-mail us the above requested information. We will be glad to further assist you.
Regards,
Vijayasarathy
Technical Support Engineer-HP e-Solutions
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
    • Out of curiosity, how do officials determine what the OEM ride height and suspension specs are? Do they have a book of truth? I'd think that would be quite obscure knowledge for random JDM cars.
    • This is the check list they sign off on. This implies that adjustable coilovers of the type we're referring to are not a "Variable Ride Height" system. This very much is in the ethos of "I can change the height while moving/while parked without pulling wheels off the car and mechanically doing so"
    • Just an update  ... Put the cat back on no issues with the car running wise ... maybe alittle longer to spoil up the turbo. Still running rich but waiting for my tuner to come back into town to retify the situation. WOT runs fine with the cat.
