Speaking of Alienware, I like that they are owned by Dell. Dell tech support just works as in they give you a new replacement computer if you ask hard enough if issues arise.
+1 Madaz, I’m with you on that one even though I have an original 60GB PS3 sitting downstairs connected to my Bravia. Use it more as a Blu Ray player and a media streamer than a games console.
i liked my ps3 so much i upgraded mine to a 250gb one and sold my 80gb one for 200bux to my mate.
got mine hook up to a 50" plasma and yamaha home theatre and use it with play tv. its awsome!
also have an shit box 360 somewhere but it just doesnt compare
My PS3 has just experianced software failure :P.
Gets that yellow light apon start up. Anyone on here to system flushs or anything to fix it or know of a place where I can get it done?
Regards,
Weez
weez, call up sony aus.
even if youve had it for awhile and tell them and they will let you know what they can do for you.
might have to send it to them and they fix it or replace it or might charge you to fix it. got mine done for free because i was a real prick on the phone haha
Regards,
Weez
Yep ring up Playstation direct, not Sony. Mine is there atm, was $250 to fix including postage.
A mate of mine had his PS3 do the same thing back in May and then a day later his Bravia LCD TV just wouldn’t turn on. He called up Sony Australia and told them straight out he wants a replacement TV and PS3 as both units were less than a year old and it was unacceptable for this to happen (this was said nicely of course :)). They agreed straight away with no fuss and a week later a brand new PS3 and TV arrived at no cost to him. If your PS3 isn’t too old I would think you shouldn’t have any issue with getting a replacement.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
